Posted by Bkpigs on August 22, 2013 at 19:55:10 from (96.40.196.68):
In Reply to: farmall 300 clutch posted by farmall4856 on August 22, 2013 at 06:37:11:
overrunning clutch would not make a difference with an IPTO. The PTO drive is isolated from the transmission when clutch is engaged. The PTO is driven off the pressure plate not the clutch disc. Will it go into reverse if you stop the tractor (push in the clutch) in gear then try to go in reverse? What confuses me is everything infront of the IPTO unit is turning constantly. The PTO is turned on or off inside the unit attached to the rear of the tractor. The only thing I can come up with is the carrier bearings for the PTO drive directly behind the pressure plate is bad, allowing the PTO drive sleeve (for the lack of a better term) to drag on the transmission input shaft. This defelection is noticed when there is a load on the PTO and the drive gears in the middle of the tractor are trying to climb each other. Just a wild hair.
