Posted by mkirsch on August 23, 2013 at 05:40:13 from (64.80.110.75):
In Reply to: farmall 300 clutch posted by farmall4856 on August 22, 2013 at 06:37:11:
How won't it go into reverse?
What exactly happens when you push the clutch, stop the tractor, and try to shift?
Does it, or does it not have IPTO? IPTO is "live" and the mower will continue to run at full power when you push the clutch. The mower will start to slow down if you have a transmission-driven PTO.
The tractor may not have IPTO, if it did not come with a TA from the factory.
On a transmission-driven PTO, if you push the clutch pedal and slip the transmission out of gear while the mower is still running, the mower will continue to drive the transmission until it runs out of momentum. You will not be able to shift until the mower is completely stopped.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
