Re: Super H belt pulley gear box.
Posted by Janicholson on August 23, 2013 at 08:27:18 from (199.17.6.160):
In Reply to: Re: Super H belt pulley gear box. posted by Superhdan on August 23, 2013 at 06:22:38:
Put an air hose in the filler hose to put a few pounds of positive air pressure in the trans case (assumes some seals are working) and it will keep trash out. Or use a vacuum at the opening to suck chips. Or remove the drive to repair. Jim
