Posted by Paul Cox on August 23, 2013 at 11:35:33 from (69.239.139.189):
In Reply to: IH 454 posted by 830 on August 23, 2013 at 07:52:02:
This has a Marvel Schebler and it is on the bottom of the intake manifold so I think that is an up-flow. It also has mechanical fuel pump on the left had side of the motor and I just replaced that. Some one also put an inline filter on the out put side of the fuel pump (dumb) and I replaced that with one that you can see the fuel pump through it so I know I'm getting fuel to the carb. Thanks.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
