Re: 1954 Farmall 400 Diesel Injection pump leaks
Posted by rustred on August 23, 2013 at 22:32:46 from (74.214.152.80):
In Reply to: 1954 Farmall 400 Diesel Injection pump leaks posted by T.R. Dickinson on August 23, 2013 at 16:08:04:
hard to tell what you are referring to, leasking diesel or oil? talking about throttle shaft? but anyhow if you are getting a raise in the oil compartment then its the diesel transfer pump that has leaking seals. if its the throttle shaft leaking then need new seal there.
