Re: Farmall M Timing Marks
Posted by D Slater on August 24, 2013 at 08:43:29 from (184.14.163.227):
In Reply to: Farmall M Timing Marks posted by LA Eric on August 24, 2013 at 08:24:28:
Can't be sure without seeing but sounds like you have a later crank pulley or a engine change. If so the first mark you came to was 40 degrees BTDC. next 30, next 25, next 16 then TDC. May want to remove the # 1 cylinder spark plug and stick something through the hole to see when the piston tops out to see if its near the mark.
