Posted by JimB2 on August 24, 2013 at 17:49:37 from (142.166.175.124):
In Reply to: IH 454 brakes posted by Walter Hardy on August 24, 2013 at 14:19:23:
Hi Walter, Do the leak down test the next morning before you start the engine. Depress each brake pedal individually and see if one or both brakes have leaked down. Check the brake lines that run from brake master cylinders under the transmission cover and under the seat to top of each axle. Check master cylinders for leaks and if no leaks found then most likely the brake wheel cylinder O-rings are leaking.
