I just put the bracket mule drive on my SA. On one side I had the stud in the top hole only. Then you can lift the mule-drive up and hang it on the stud then raise it to the other side and put in a bolt. Then you can easily put in the other 2 bolts on each side. The mule-drive I have is Woods made and I guess they make them a little short to make sure they'll fit between all finals on all tractors. I had to shim out each side 1/4". Also make sure you don't use bolts that are too long or you'll punch a hole in the final when tightening. On each side, 2 of the holes are tapped all the way thru so the length is not critical but on one hole it has a bottom. If you put too long a bolt here and over-tighten you can crack the final into the oil resevoir and end up with a leak. Best to slip a tape measure in this hole first to make sure your bolt is not too long. If you haven't used these holes best to run a tap in them first to clean out junk or rust. On the threaded thru holes, 2" bolt with lockwasher is good, the other hole best is 1 1/2" bolt with lockwasher. If you can find 1 1/2" bolts this is good everywhere. I bought my bolts at Tractor Supply and the shortest they sell in 3/4" is 2" so I had to cut down 2 for the blind holes.
The Woods diagram calls for 1 1/2" bolts and standard washers for shimming. You may need to use more than one washer on each side to shim snug before tightening.
Gerry
This post was edited by Gerry Powell at 20:37:45 08/24/13.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
