Re: 184 International Lo-Boy
Posted by K-Mo on August 25, 2013 at 06:56:31 from (66.43.226.235):
In Reply to: Re: 184 International Lo-Boy posted by Buster on August 25, 2013 at 05:49:18:
For a good running 184 with 3pt and creeper, $1200 isn't a bad price. Depends on what you want to do with it. If you want to mow with, you may be able to find a deck for it and still be okay value wise. If you want a new deck, although probably a little pricy, WOODS (59LB-1) may still sell them. Used decks are probably available depending on where you are located.
If you want to use a front or rear blade, with turf tires, you will probably need tire chains. To install tire chains you will need wheel spacers to allow for fender clearance.
K-Mo
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
