Re: Duals for 1586
Posted by IH fan on August 25, 2013 at 07:32:29 from (68.102.238.6):
In Reply to: Duals for 1586 posted by Dave H (MI) on August 25, 2013 at 06:54:09:
I imagine most big tractor salvage places would have wheels that mount on your hubs. If your current tires are worn, put them to the outside and get new or better ones for inside.
Only advice I can give on duals if you've never used them, is the outer tires should have a couple of pounds less air pressure than the inner ones. Being farther out, you more leverage going over rough places and you need a little extra cushion so you don't break an axle.
