Re: need help attaching belt pulley to super a farmall
Posted by Haas on August 26, 2013 at 03:29:31 from (50.142.111.41):
In Reply to: Re: need help attaching belt pulley to super a farmall posted by Gilbert Kiser on August 25, 2013 at 21:27:10:
Heating won't hurt it. Have you soaked with PB Blaster from the back side? Keep soaking and use some heat it should eventually break loose. Next option would be to weld a nut on the stripped end or to drill it from the back side. If you drill it, start with a smaller bit and gradually use larger bits. Don't use cheap bits and be very careful not to break off a bit in there. As your hole gets bigger, keep trying to unscrew the stud, as the hole will relieve the pressure on the threads. Keep at it, you will eventually get it.
