Re: need help attaching belt pulley to super a farmall
Posted by mkirsch on August 26, 2013 at 05:50:23 from (64.80.110.74):
In Reply to: need help attaching belt pulley to super a farmall posted by Gilbert Kiser on August 24, 2013 at 12:47:45:
Concentrate the heat on the stud. Get it red hot then let it cool. Be patient.
You want the bolt red hot, not the casting. You need an oxy-acetylene or oxy-propane setup. A Bernz-o-matic click torch is only good for roasting hot dogs or lighting cheap cigars in this case.
The heating of the stud expands the casting slightly, and should release the bolt.
