Re: 706 gas head on a 560?
Posted by Roger Tomfohrde on August 26, 2013 at 05:52:05 from (74.5.82.133):
In Reply to: 706 gas head on a 560? posted by Unstylish on August 26, 2013 at 03:55:09:
If the 560 has step head pistons it may not fit. I found a 656 head for my 560 but the smaller not full diameter combustion chamber it has would not have the clearance needed. It would have more hp because the ports are larger and the valves bigger. An early 706 may fit but you need to see what pistons are there and if there is clearance. It would bolt on though if it has the space. There is I believe six casting numbers that all are the same configuration, Good luck in your search.
