Re: Cub PTO direction
Posted by ericlb on August 26, 2013 at 06:47:04 from (70.41.155.192):
In Reply to: Cub PTO direction posted by reb-in-pa on August 26, 2013 at 06:20:11:
i dont think so, the cub pto runs at engine rpm, and in the opisit direction of "normal' unless you can rig a belt to spin the generator the other direction there would be no way to reverse its direction using a direct drive shaft
