Re: Cub PTO direction
Posted by Buzzman72 on August 26, 2013 at 06:57:44 from (74.138.168.131):
In Reply to: Cub PTO direction posted by reb-in-pa on August 26, 2013 at 06:20:11:
An outfit called Hub City used to make a gearbox that bolted to the PTO housing on a Cub. It would reverse the direction AND reduce the speed by about a 3-to-1 ratio.
In the '60's, they were a lot more common...and $75-$100 would buy one. Last one I saw for sale anywhere was in the $900-$1000 range.
