Re: 1954 Farmall 400 Diesel Injection pump leaks
Posted by n9lhm on August 26, 2013 at 08:08:34 from (38.111.252.2):
In Reply to: 1954 Farmall 400 Diesel Injection pump leaks posted by T.R. Dickinson on August 23, 2013 at 16:08:04:
If that"s a B series pump (no scavenging valve and pump)then the drain tube in the bottom is probably plugged with dirt and the leakage fuel from the valves is building up in there and overflowing. Run a piece of wire up through the drain tube and you will probably get dirt and a rush of diesel fuel out of it. The pump can then drip out the leakage fuel and it won"t be finding its way out the throttle shaft.
