Re: super MTA hydraulic pump
Posted by D Slater on August 26, 2013 at 12:37:07 from (184.14.163.227):
In Reply to: super MTA hydraulic pump posted by SMTA_owner on August 26, 2013 at 10:24:13:
Look for 450 tractor parts. Click hydraulic then numbers 371 and 373. 371 is a pesco pump and if I remember correct that's what originally came on SMTA. Remember them having the same size seal on both ends of the pump. If its has a Thompson pump some of those used a different size seal on one end. I'm thinking at one time the parts look up had a discrepancy on which seal was right. To be sure, may want to remove the seals to see if the pumps in good enough shape to replace the seals. All the seals I ever removed from them had a number on them.
