Re: broke off temp sending unit in head
Posted by cushman on August 26, 2013 at 19:17:06 from (71.48.71.172):
In Reply to: broke off temp sending unit in head posted by charlespretzer Ks. on August 26, 2013 at 15:48:58:
If you are good with a welder,try getting a nut almost as large as the fitting ,and weld it to it.When it all cools it will partialy shrink the fitting and give you something to use a wrench on to back it out.We often do that in our shop to remove broken bolts etc.You might have to go at it a couple times.
