Re: 300U steering wheel
Posted by 504-1 on August 26, 2013 at 19:45:35 from (199.127.54.155):
In Reply to: 300U steering wheel posted by Danby on August 26, 2013 at 11:22:33:
Air chisel with a hammer bit, you grab the wheel with your left arm and pull as hard as you can and hit the air hammer at the same time. Make sure you have a nut on the threads for two reasons, one to keep the threads protected, and the most important, to keep the wheel from hitting you in the teeth when it comes off.
