Re: Just anouther what would you pay
Posted by farmall300u on August 26, 2013 at 23:40:38 from (70.170.42.54):
In Reply to: Just anouther what would you pay posted by 504-1 on August 26, 2013 at 19:52:04:
After buying and fixing up my 300u, here are the key factors affecting conditions/price:
1. Hydraulics: Are all three valves working, handles tight, 3 pt works correctly, high pump pressure, etc.
2. TA works, no slipping under load.
3. Live pto under heavy bush hog load does not slip, will stall engine
4. Power steering works, no wobble going down the road in 5th gear,
5. Each cylinder has good compression & oil pressure
6. Rims/tires are in great shape and loaded
7. All cosmetic items work, lights, radiator, seat, etc.
if your 300u meets all of these items, it is worth $3,000 minimum.
