Re: broke off temp sending unit in head
Posted by gene bender on August 27, 2013 at 03:39:17 from (67.55.226.50):
In Reply to: broke off temp sending unit in head posted by charlespretzer Ks. on August 26, 2013 at 15:48:58:
Sometimes those are brass i would clean it to see if yours is. You will need a pipe extractor if you go that way sometimes the twisted ones will work the best make sure its a name brand and not an import. Next option would be a die grinder. Working maintence found out all broken stuff like that take different approackes.
