Posted by reb-in-pa on August 27, 2013 at 07:02:50 from (134.198.95.153):
In Reply to: Cub PTO direction posted by reb-in-pa on August 26, 2013 at 06:20:11:
Gene --
I'm a little confused. Everything else I've read indicates that the Cub would have too high rpm because the PTO runs at engine speed, rated at 1800 rpm. The Hub City reverser that used to be available changed the direction and reduced rpm's 2.73:1.
And, do you assert that the Cub won't run a "large" generator because it lacks the power? My generator is a 12Kw, and the Cub was rated new at 8.8 hp, I believe.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
