Re: Cub PTO direction
Posted by mkirsch on August 27, 2013 at 10:36:53 from (64.80.110.74):
In Reply to: Cub PTO direction posted by reb-in-pa on August 26, 2013 at 06:20:11:
12KW is approximately 16HP.
Power transfer is not 100% efficient, so you actually need closer to 25HP to run a 12KW generator at full capacity.
The Cub will not have enough power to run a 12KW generator at even 1/2 capacity.
