Re: FEL Hydraulics for 584
Posted by Dodgerdoob on August 27, 2013 at 13:24:42 from (66.244.68.17):
In Reply to: FEL Hydraulics for 584 posted by Dodgerdoob on August 26, 2013 at 05:51:49:
If the hose outlined in green in the 2nd picture is attached to the fitting below the right rear axle you already have a power beyond on the tractor. Run supply to your loader valve from the fitting and return from the loader valve into the rear frame where that hose is attached.[/quote]
That is the best idea I have heard yet. I couldn't figure out what that hose did, knew it wasn't factory. There is a plate on the side of the rear remote valve that the hose comes out of, loops around the axle and goes into the bottom side plate on tranny. Makes sense that when the previous owner took off the FEL or something else, he just looped it and had it dump back in the reservoir. Don't know the history of this tractor, but I'm only the second owner. There is also a big extension pipe going into the hydraulic fill port behind the seat That lends me to think it had some other hydraulic attachments at one time.[color=red:3f72c9441a][/color:3f72c9441a]
