Posted by D Slater on August 28, 2013 at 04:34:21 from (184.14.163.227):
In Reply to: 2 speed in a H posted by Bradiniowa on August 27, 2013 at 16:50:07:
Cable should go into the clutch or center housing then through a special dowel pin in the front transmission wall. Then it hooks to a lever something like K-10 in the picture. # 8 goes in the shifting sleeve 7 slot and through pins moves a splined or teeth like shifter that can lock two different sized constant mesh gears. Lever forward is high range and back is standard range. Picture is a lever shift but just imagine the lever shift parts missing and the shift lever 10-K made different on the end to retain the shift cable. look through the belt pulley gear box opening to see what's there.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
