Re: IH 684 Rear Frame Cover Assembly Removal
Posted by Jim Naden on August 28, 2013 at 09:13:15 from (63.151.142.198):
In Reply to: IH 684 Rear Frame Cover Assembly Removal posted by jmapleIH684 on August 28, 2013 at 05:28:00:
The rear frame cover is best handled with a hoist as it is heavy to the front right and a bit awkward.
For the rear frame cover you will need a gasket and some o-rings that seal the brake bleed ports and a lube port.
The pin that retains the PTO clutch to the shaft is 5/16" IIRC.
Good idea to use a new one going back together.
Be carefull of the metal sealing rings on the PTO output shaft. I have seen them broken due to careless handling.
Would be a good time to install a new parking brake band while you are right there too.
This post was edited by Jim Naden at 09:18:00 08/28/13.
