Replacing bearings SA transmission shaft
Posted by Gerry Powell on August 28, 2013 at 09:39:34 from (173.172.82.103):
Can I remove the transmission shaft that drives the PTO (number 20 in the TC-39 page 166) without removing the transmission from the tractor? My bearings are worn and sloppy causing the shaft to knock in the rear bearing.
