Sounds like you have hooked your test gauge and valve right into the line from pump to steering valve, and also sounds like the flow has to go through your valve and cannot get around it. If so, then you have indeed confirmed you have very little flow and pressure so your pump would indeed be bad. Realize though that the pump contains the combination pressure relief and flow divider valve so that could be stuck or broke. Might be worth checking that out when you pull pump out. Should have 1200 psi and 3.5 gal flow per minute at about 75 percent of that max pressure.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
