Re: H Belt Pulley runs Hot
Posted by Janicholson on August 28, 2013 at 14:55:35 from (74.60.94.18):
In Reply to: H Belt Pulley runs Hot posted by Sawdusty on August 28, 2013 at 14:38:10:
Bevel gears in a drive train pass about 95% of the power input. Thus if you were pushing 15hp there was 3/4 hp as waste heat in the drive. The belt was pretty efficient (probably 96% but friction driven and air cooled) some of that heat is transferred to the drive. and last, the engine is probably at 160+ degrees and conducting heat into the drive through iron. It is fine. Jim
