Re: 706 injection timing
Posted by Dieseltech on August 29, 2013 at 10:20:13 from (98.206.80.148):
In Reply to: 706 injection timing posted by Tom St on August 29, 2013 at 10:07:37:
Tool is for checking cam ring movement with engine speed. Each mark is 2 degrees pump. D282 in 706 has speed advance of 3 degrees pump, or 1 1/2 marks. Spec is 1 degree at 1400-1600 and 3 degrees at 1900-2100 engine RPM. That is at full throttle on the test stand. No load on engine will be a bit earlier on RPM range.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
