Re: electrical problems on the starter ???
Posted by Brownie 450 on August 29, 2013 at 14:16:17 from (66.43.241.198):
In Reply to: electrical problems on the starter ??? posted by kevin oh on August 29, 2013 at 10:40:39:
Read your voltage on that terminal when the key is held in start position. There is possibly a bad connection at a lug on any wire in the start circuit. The best way to isolate the problem is with a jumper wire with alligator clips on the end.Work your way back from the solenoid toward the ignition switch to find the problem. Bear in mind, that the problem could be a faulty ignition/ start switch.
