Re: electrical problems on the starter ???
Posted by Owen Aaland on August 29, 2013 at 15:26:12 from (216.47.35.45):
In Reply to: electrical problems on the starter ??? posted by kevin oh on August 29, 2013 at 10:40:39:
That is a classic example of a poor connection. You have voltage when there is no load on the wire but as soon as you add a load your poor connection becomes high resistance. Since you know the starter works when jumping the battery terminal to the S terminal you know the starter works Okay. The problem is in the tractor harness, switches or connections.
Power comes from the battery terminal at the starter up to the ammeter to the key switch to the safety start switch on the clutch pedal and then back to the S terminal on the solenoid. Your problem is in there somewhere.
