still wont crank
Posted by twiggcas on August 29, 2013 at 18:15:37 from (173.3.236.141):
I post a couple weeks ago about a farmall m with starting issues,(new battery, rebuilt starter, cables, starter button), it runs if u tow start it(not great though) but will not crank all the way over with the plugs in it seems too much compression. I will crank with plugs out, so I pulled the valve cover and noticed the second valve in from fan shaft has a bent push rod. is that exhaust or intake, and if it was exhaust would it no release the compression full therefore build up too much in that particular cylinder? what would cause push rod to bend, the valves are all free. hyrdolock? I was told from the guy I bough it from said a push rod was bent but was straightened but didn"t specify which cylinder or intake or exhaust. how can u check valve timing with out pulling front cover off to see marks on camshaft?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
