Re: Removing calcium chloride
Posted by 504-1 on August 30, 2013 at 19:42:49 from (199.127.54.155):
In Reply to: Removing calcium chloride posted by Brent in IA on August 30, 2013 at 19:30:46:
Just buy a new valve stem,(they need to be changed about ever 5 years) put the stem at the top, take out the old one, and put in the new one. The only information you will need to do this is, does your tube have an inside thread or an outside thread. Just ask at a tire store and they will fix you up for $5.00
You will need a pair of pliers and a air hose. If you drain the CC out the loader will be worthless and dangerous.
