Re: Removing calcium chloride
Posted by bmartin5566 on August 30, 2013 at 20:59:04 from (24.160.181.63):
In Reply to: Removing calcium chloride posted by Brent in IA on August 30, 2013 at 19:30:46:
i take the valves out.. get a small hose. i thinh 5/16 air line.its black in colar. shove it in the tube tape it around the stem to make it air tight...then blow air in the hose ..when u take the air off it out it comes''''do this several times..and u will get it all out''...i do this to lighten up my loaded tires...
