Re: Timing trouble with farmall M magneto H4
Posted by oldtractor123 on August 31, 2013 at 13:22:18 from (108.59.112.204):
In Reply to: Timing trouble with farmall M magneto H4 posted by Janicholson on August 31, 2013 at 12:15:28:
Thanks Jim
Do you mean I could have sheared the pin or Woodruff on the
mag drive shaft on the tractor itself ?
Because the mag was locked tight.
I don't remember exactly where the position of the drive slot is on the tractor. Something like the 10 and 4 clock positions.
Can someone post a picture or tell me what positions the drive slot should be in for #1 cyl TDC on compression ?
