Re: cub c60 engine piston diameter at top and at skirt
Posted by Owen Aaland on September 02, 2013 at 07:12:40 from (216.47.35.244):
In Reply to: cub c60 engine piston diameter at top and at skirt posted by was8478 on September 01, 2013 at 08:49:18:
The pistons will change shape as they heat up in use. As they expand they will become more round rather than oval. The cam grind is to help them be the correct shape while the engine is being run.
The same hold true for the smaller diameter at the ring lands. The top of the piston runs hotter than the skirt. If the ring land area was not smaller the piston would rub the cylinder wall rather than the load being carried by the skirt.
