Re: No Start on my H
Posted by The Red on November 30, 2000 at 15:19:14 from (12.75.197.189):
In Reply to: No Start on my H posted by farmall man on November 30, 2000 at 14:04:14:
FM as Lyle mentioned, I bet you are well out of time. Rotate the engine until you have #1 cylinder on top dead center on the compression stroke. Look at the position of the rotor. Turn the distributor body so the points just open. Note which distributor post is lined up with the rotor. That will be the wire that goes to the number 1 cylinder. Then clockwise, wire to 3, 4, and then 2. I have been through this problem on a JD 4400 combine gasser. Let us know what happens!
Post A Followup
: Re: Re: No Start on my H
