I've had similar problems. For the radiator cap, first smooth the surface of the radiator where the cap goes with a wire wheel or wet/dry sandpaper (depending on condition) You can use JB weld if you have any really bad pits. The caps can be pretty rough too, so do a similar treatment. IF possible, get some gasket material quarter in. in thickness (from your local NAPA store). If not available, glue two thinner gaskets together with silicone. Cork is OK, but rubber type material is better. Side covers are a pain too. Smooth up the surface. I used RTV with the gaskets and that worked. YOu could even use just RTV as I doubt you'll be opening these up. Hope this helps.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
