Re: can a bad kill switch cause intermitenent shut
Posted by old on September 02, 2013 at 08:27:17 from (209.86.226.32):
In Reply to: can a bad kill switch cause intermitenent shut posted by ericlb on September 02, 2013 at 07:30:54:
Remove the kill switch wire from the mag and see if it stops having a problem. On a mag to shut it down you ground the system so removing the wire at the mag will tell you if you have a short or bad switch. Any tractor I have with a mag I shut them off by turning off the gas which you should do on any tractor
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
