Re: Giving up on MD
Posted by Janicholson on September 02, 2013 at 15:24:24 from (74.60.94.18):
In Reply to: Re: Giving up on MD posted by kluegcollector on September 02, 2013 at 12:45:57:
The fact that it runs on the D side is great. The pump is not tough to look at and fix. The problem may be that the rack is stuck. only allowing a small amount of injection. Take the cover off and look at the system to see if there is movement when operating the fuel lever (throttle) a little solvent and effort might get it operational. Some older local person and a case of malted beverage and it runs. Jim
