Kind of depends on which ones are off center. The rocker shafts are pressed into the center oiler piece and may be pressed in too far or not far enough if it is the end rockers giving you trouble. Most likely though, just mfg's tolerence. If they are not the cast rockers you can bend them a little but they might twist when doing that and not push squarely on valve. I usually just position the supports to their best position and let it go at that. Have to make sure the rocker has a bit of side movement also so it does not bind.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
