Posted by DeltaRed on September 02, 2013 at 18:55:29 from (97.118.31.225):
In Reply to: Re: 706 hyd ports posted by DeltaRed on September 02, 2013 at 18:09:01:
Your tractor has a 12 gpm pump.The 'Farmhand' pto pump is probably around 20 gpm. The loader will be slower useing the tractor.You may need to replace the relief valve (under the right side of the seat),as the original 1450 psi wont have enough 'poop'.A 1486 reliefe is around 2500 and will fit.There is an optional/replacement pump that is 17 gpm,an even bigger one may be available.Running the loader from the tractor hydralic pump may somewhat shorten it useful life.Also add 5 gal extra oil (overfill)to the system to 'compensate'
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
