Posted by 2 pipe on September 02, 2013 at 19:04:58 from (172.243.198.67):
In Reply to: SMTA shifter posted by Dave H (MI) on September 02, 2013 at 18:55:13:
I have had this happen to me before, if it was in first gear when it popped out the trick is to point the shifter the same way it would usually be when it is in first gear and try to get it back in that same shift rail. If that doesn't work then you may have to get a small pry bar in there and slide the rail back to neutral, this is not real easy because you can't see down in there while you are trying to pry it back and they don't always move real easy.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
