Re: 1066 PTO problem
Posted by The tractor vet on September 02, 2013 at 20:50:37 from (76.212.228.18):
In Reply to: 1066 PTO problem posted by NHBalerman on September 02, 2013 at 19:38:54:
NO it is NOT the pin . If the tiny pin is sheared then you will not have a PTO . (1) when does it quit working ?? when going down hill ??? add more hyd fluid . (2) does it slip under load ??? If it has slipped under load then there is a good chance that it needs rebuilt and you don't stop at the clutches ya need to check the housing where the clutch drum runs in and ya look for ware where the teflon seal rings ride . (3) ya need a special fitting and a gauge that will read 600 PSI to check clutch lock up pressure and Lock up pressure MUST BE CHECKED with the Hyd oil AT WORKING TEMP. And the gauge should read for a 1066 245-265 PSI .
