Re: live pto for Farmall H
Posted by mkirsch on September 04, 2013 at 05:06:19 from (64.80.110.74):
In Reply to: live pto for Farmall H posted by Bob And on September 03, 2013 at 19:21:03:
After all that, it's not really "live PTO." The M&W hand clutch system simply stops forward motion of the tractor. You still need to push the clutch pedal to shift, which stops the PTO.
Installing is a J-O-B job. You basically need to disassemble the tractor's differential and final drive section to install it.
Parts are no longer available except for standard seals and bearings. You could buy a used one, go to all that work to install it, only to find out it's worthless junk and doesn't work.
Your best bet to get live PTO on an H is to sell the H and buy a good used 300 or 350.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
