Re: 756 hydraulics
Posted by mkirsch on September 04, 2013 at 05:16:54 from (64.80.110.74):
In Reply to: 756 hydraulics posted by Nw_bearcat on September 02, 2013 at 19:44:06:
A 12' Hesston mower/conditioner is HEAVY and the lift mechanism is a pi$$ poor design. Dad's got the CaseIH version. The 856 won't lift it all the way up, even with a new pump. The 1066 BARELY lifts it and I think it's set for 2000 PSI.
The only tractor that will lift it is the Maxxum, and I think that has a 2500 or 3000 PSI hydraulic system.
Even with a new pump and a high pressure relief valve it may not be enough to lift the mower.
On the 766, it might have a hydraulic seat or it might not. Most of them have mechanical seats that I've seen.
The valve stack will bolt right into the 756. They are identical for all practical purposes. No need to go further than that.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
