Re: farmall A gen. belt removal
Posted by old on September 04, 2013 at 08:56:13 from (209.86.226.27):
In Reply to: farmall A gen. belt removal posted by farmall plowboy on September 04, 2013 at 08:40:23:
The fan hub has a couple lock nuts on it. You loosen those nuts and then you turn the one hub part so it loosens up so that in turn let you remove it form the crank shaft pulley. They can be a bear to get to loosen up so you may need to use a punch and hammer
