No there is not a special tool to remove the belt. If your tractor has a water pump one of the two pulleys has a set screw in part of the pulley. Loosen the screw (I believe it is a 1/2 inch wrench and a flat screwdriver) and turn the outer half of the pulley. If it does NOT have a pump the spindle the main pulley is mounted on (i.e. where the pump would be) has 2 flat spots on the shaft behind the pulley to loosen ALL the belts.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
