Re: farmall A gen. belt removal
Posted by kris Jensen on September 04, 2013 at 09:21:19 from (70.67.18.208):
In Reply to: farmall A gen. belt removal posted by farmall plowboy on September 04, 2013 at 08:40:23:
I have just gone through the process of putting on a new generator belt. It is not as long as it looks when you are going to install it. It will not fit over the fan blades one at a time, and removing the spindle, (nut and washer behind the support, flat spanner in front) will not give you clearance, at least not on my 44 A. Spare yourself a lot of time and effort. Drain the antifreeze and take off the radiator. That is so you can get the fan blades clear of the contraption it is bolted to. Rest of the job is easy. I cleaned my fan blades and did a bit of painting while assembly was apart. good luck.
